Well, the floor is done, and it's about time to start the walls next weekend.
Here's my question for you... what is the best way to transfer the outline of the teardrop to the wall? Here are my options...
1. Use the cad program to print a full sized side view, tape that to the plywood and use that.
2. Come up with a list of measurements from the end of the trailer (x,y) type coords, mark them on the plywood and then draw in the connecting lines.
Option 1 would be possibly the most precise, (more precise than I can cut to be honest), Option 2 might be quicker, but I can see myself spending a LOT of time with the drywall square making sure that I've triple checked all the measurements.
I only have to cut one side precisely, I plan on then trimming the other side slightly oversized and finish it with a flush trim router bit, using the first one as a template.
Any advice would be appreciated.
Steve W
