by doug hodder » Wed Jan 16, 2008 10:13 am
1 or more coats of CPES? What type primer/ paint are you planning on? Some can hide scratches much better than others. If it's all smooth and sealed, just scuff it to give it some tooth for the paint to bond to, don't get carried away with sanding. If you get into the wood with your sanding, it's probably going to need to be touched up in that area with another application of CPES. Kinda depends on what you want your final finish to look like. If you are going to apply an automotive finish, then it's different deal. Doug
