roof construction
roof construction
Postby carpenter » Wed Jan 16, 2008 6:54 pm
Has anyone ever used ice & water sheild under alm skin I've heard of some using rubber roofing under alm
carpenter
Postby bobhenry » Wed Jan 16, 2008 7:05 pm
While it is is an excellent product, ( I used it extensively under the lexan roof) I don't think there is a soul alive that can put it down without a wrinkle or pucker. As thin as the aluminun skin it it will telegraph to the surface. If you want a water shield product use duramate or a house wrap it will prevent permiation while allowing the aluminum to breath and float with the expansion and contraction. Just my opinion
Bob
Postby mikeschn » Wed Jan 16, 2008 7:10 pm
why not just fiberglass under the aluminum skin? at least with that you can come up with a finish as smooth as a wooden kayak!
Postby goldcoop » Thu Jan 17, 2008 7:02 am
Carpenter-
Why use anything under the Alum. skin?
Everything you add will add weight, aren't you trying to stay under 1,000lbs. for a 5' x 10'?
Coop
goldcoop
Images: 32
roof construction
Postby carpenter » Thu Jan 17, 2008 6:33 pm
I was only making a sugestion for others.
carpenter
Users browsing this forum: Bing [Bot] and 7 guests
