Greywater
Greywater
Postby mallett » Sat Jan 19, 2008 6:26 pm
Made this grid out of 2" PVC pipe. It 51" by 24" which gives me about 25'. I found a program that figures the volume of pipe and it comes to 4.7 gals. I am planning on installing it under my teardrop between the 2" tubing. I have the inlet and outlet but will have to vent it.
Here is a link to the neat program for figuring the volume of pipe.
pages.prodigy.net/rich_demartile/files/pipe-vol.xls
Every man's work, whether it be literature or music or pictures or architecture or anything else, is always a portrait of himself.
- Samuel Butler (1835-1902) British writer.
mallett
Images: 61
Postby Classic Finn » Sat Jan 19, 2008 7:49 pm
Now thats impressive... :thumbsup: :thumbsup: :thumbsup:
As is your tear.. very nice.
Classic Finn ;)
Classic Finn
Midnight Sun Voyager
Images: 146
Postby Miriam C. » Sun Jan 20, 2008 12:14 am
:applause: :thumbsup: Thanks for sharing the water tank with us. Really neat!
Postby prohandyman » Sun Jan 20, 2008 7:21 pm
Iv'e been thinking about a similar system. By greywater, I suppose you mean sink waste water. If so, most sink water has food particles in it, so wont they possibly clog those small outlet connectors? Your design is very cool, but if you tee into it with say 1" and run a drain line out to the side of your tear, you could install a shut-off and drain wastewater into campground greywater disposal drains. Just thinking out loud! :thinking:
Dan
prohandyman
Images: 785
Postby mallett » Sun Jan 20, 2008 8:24 pm
Dan,
You make a good point. I think I'll make the drain outlet bigger. I plan to run a clear vinyl line out to the left back corner and attach a plastic hose cut off value. If it gets stopped up there I can just take it off and clean it out.
Thanks for the input
Mallett
mallett
Images: 61
Re: Greywater
Postby bobhenry » Sun Jan 20, 2008 8:35 pm
mallett wrote:Made this grid out of 2" PVC pipe. It 51" by 24" which gives me about 25'. I found a program that figures the volume of pipe and it comes to 4.7 gals. I am planning on installing it under my teardrop between the 2" tubing. I have the inlet and outlet but will have to vent it.
Make a hell of a roof rack and you could gravity feed the water too.....
Postby mallett » Mon Jan 21, 2008 7:06 pm
I installed the greywater grid under the tear. here are some pics.
mallett
Images: 61
Postby prohandyman » Mon Jan 21, 2008 7:47 pm
Great job! :thumbsup: :thumbsup: Thats what I want for Christmas! Wait...I will have to make it first! Thanks for sharing!
Dan
prohandyman
Images: 785
Postby mallett » Mon Jan 21, 2008 8:40 pm
Thanks Dan for your idea of making the outlet 1". I also made the inlet 1".
That's what is great about this forum. People sharing their ideas and then others improving on them.
Mallett
mallett
Images: 61
Postby Esteban » Mon Jan 21, 2008 8:43 pm
:applause: You've come up with an innovative solution to use the empty space under the frame for a gray water tank.
Do you have a fresh water tank too or is your fresh water supplied by a hose connection from the outside?
If you can please label the water hoses/drains/vents in your under counter picture to let us know what each of them are for? :thinking:
Seems to be reasonable that, as an alternative, we could make a similar space saving under frame fresh water tank. :thinking:
Steve - SLO, CA
Esteban
Images: 15
Postby mallett » Mon Jan 21, 2008 8:49 pm
Steve,
I do not have a fresh water tank but I can take a water container and use my Colman hot water if I'm ruffing it to pump water to the sink.
Mallett
mallett
Images: 61
Re: Greywater
Postby Alphacarina » Tue Jan 22, 2008 7:43 pm
Since there's no pressure on your 'tank' you could have cut half or three quarters of an inch off of each side of your Tees and Elbows and you would have had room to add a sixth cross pipe to your 'tank' - That would have given you about another three quarters of a gallon of storage capacity :D
Don
Alphacarina
Postby mallett » Tue Jan 22, 2008 9:04 pm
Don,
I thought about that but decided that 4.7 gals. would be sufficient. Thanks for the input.
Mallett
mallett
Images: 61
Postby prohandyman » Tue Jan 22, 2008 9:18 pm
This is the link to the water tank Madjack did
http://www.tnttt.com/viewtopic.php?t=7415&highlight=pvc+water+tank+madjack
Dan
prohandyman
Images: 785
Postby cuyeda » Tue Jan 22, 2008 9:23 pm
Mallet,
Great possibilities with your grey water tank. Congratulations! Here are a couple of MadJack's photos, to add to the think tank. Aside from ordering custom tanks to fit, the alternative less expensive alternative would be appealing. I haven't made anythiing yet, but would be great if others can improve on any of the ideas here.
Cliff & Vanessa
cuyeda
