by angib » Mon Jan 28, 2008 10:21 am
Everyone tends to assume that the walls are held up by the floor, but on a teardrop that isn't necessarily true, once the body is assembled.
That photo of Steve's Puffin is an excellent example. While he was building it, sure, the walls were held up by the floor, particularly at the stage where there was only a floor and two side walls.
However, once complete that front wall and its twin at the back are sitting right on the frame and are way, waaaay stronger than the floor which is just a trampoline by comparison. You must all have played that game at school with holding a ruler flat and seeing how much it can carry and then doing the same with it vertical, when it can carry much, much more (maybe 10 times as much).
So what Steve needed was a good connection between the sides and the front/back (I see lots of screws into a wood fillet inside - perfect) and then a good connection between the front/back and the frame.
Most teardrops don't have a back wall, but they have something better, a galley bulkhead - that always crosses the frame (providing a strong support), so then the only need is to connect the front wall to the trailer frame.
Now..... all this changes if the body overhangs the frame lengthways as well as widthways. By overhang, I mean 6" or 12", not an inch or two. Then we have got the body held up by the trampoline floor, so lots of extra strength would then be required in the floor.
So Michele, the question is will your front and back walls be supported on/close to the frame - if so, just an unframed ply floor will do.
Andrew
