Gerdo wrote:brian_bp wrote:Johnny's talking about diameter, and didn't mention width.
The adapters that I have seen are usualy made out of an aluminium ring that bolts on and has studs in the new bolt pattern. They are usualy 1.25"-1.5" thich to clear the original studs. Moving the wheel outboard.
Yes, that's a good point, and I was focusing on the diameter and forgetting that the way to get there was to be an adapter. Good catch, Gerdo.
On the other hand, if a car or truck wheel is used, it probably has more offset anyway, and after allowing for the adapter could be anywhere... more or less offset than the original trailer wheel (likely near zero offset) directly on the hub. Sometimes, two "wrongs" effectively make a "right".
A wheel of the
same offset, plus an adapter, is definitely moving the wheel centre out and causing the issues which Gerdo described.
