SlumberMAX headliners, hullliners, and headaches (aaaaagh)
Well I finally collected enough volunteers to slip in the headliner for the SlumberMAX. I framed it with a 1/4 slot to float the headliner. I was figuring 1/8 inch ply backer and a 1/8 inch headliner material....
Well...I ended up with a thicker material for the headliner...it was a hull-liner material like you put in boats...sure enough...it was so snug in the slot that the work crew could only get it about 90% done...and we pulled and we pushed...and the chief mate (Marcia) finally gave up!!! We got it to about 10 inches from in place...
On the bright side...the headliner fit so snug that I won't need any trim on the walls to the roof....
I guess I'm a goin to have to use some ingenuity to make this look like I planned it this way!!!!
