Question about sealant
Postby Michele » Mon Feb 04, 2008 8:45 pm
Is there a sealant that will adhear to the black goo that I put on the underside of my floor? I need to reattach my plastic wheel well covers. The lip of the covers will be up against the tar side of the floor. I plan on attaching them with staples as that is the way they were on originally but I also need a sealant.
Michele
Images: 120
Postby toypusher » Mon Feb 04, 2008 8:57 pm
You could just put a little more Black Goo on and press the fenders into it while it is wet, staple (or screw) them in place and they should be sealed.
toypusher
Images: 324
Postby Ken A Hood » Mon Feb 04, 2008 9:15 pm
You could also use ice/water shield they use on roofs....will stick to anything and is flexible (so it won't crack)
Ken A Hood
Images: 42
Postby madjack » Tue Feb 05, 2008 8:50 am
...you can get the black goo inna caulk tube and use it to install the wells...I would consider screwing them in place instead of using staples...also butyl tape(not caulk) would work as well if using screws to attach with............
Postby SteveH » Tue Feb 05, 2008 8:55 am
Silicone sealant will stick to the black goo.
SteveH
SteveH
Images: 42
Users browsing this forum: Google [Bot], Jimbodub and 3 guests
