I've used the typical T handle on the last 3 tears, but got a 40 Ford deck lid handle for this one. It's an aftermarket unit. What's nice is that it has the license plate light built into it, also has a stainless flap with a chevron pattern that flips over the key hole. The correct light socket required Mike Ahearn doing some hunting for me, but the rest of the parts are readily available. License plate bracket is also a 40 Ford. I did have to modify the internal parts a bit to get it to swing enough to work the rods, as well as the base a bit since it is getting mounted on a flat surface. I think the curve would work perfectly on a hatch curve like on the Trailer for 2 profile, just an idea.
3rd light is from a 48 Plymouth, I had to make a sub-base for it to match the curve of the casting. It will all be faired into the hatch using epoxy for a fillet all around it. The base was a hassle to make. I doctored up a cheap "beehive" type clearance light to go behind the glass lens. Yes, I know, I need a plate frame. Doug
