by angib » Fri Feb 15, 2008 12:54 pm
I'm surprised for such a heavy frame that you're only using a 30" tongue - you could go up to 36" at least.
Unlike Rocky (asianflava), I like the diagonals as they take some load directly from the coupler to where it's going, the side rails. It also makes building a secure base for a tongue box easy.
With 3" tube tongue onto a 2" tube frame, the two cross-members holding the tongue need to be well apart (just as you have shown them), otherwise they will fail before the tongue does.
52" does seem a long way forward for the axle. You say you're planning to add ice chest, batteries and water tank to the galley and they weigh a lot, so you won't have a light galley. OK, you will have a good load on the front from the AC, heater and genny, but at a first guess I'd say those only cancel out the stuff in the galley.
With so many heavy weights, you would be better to use my spreadsheet - one weight for the trailer frame/body, one extra for the stuff in the galley and one more extra for the stuff up front. I'll be surprised if you get more than 44-48" as an optimum. If you want help with it, send me the figures.
Andrew
