A/C Installation
A/C Installation
Postby sdn40 » Sun Feb 17, 2008 8:33 pm
Hello
Newbie here currently designing my first after days of sleep deprivation thanks to this forum - LOL.
A/C installation seem to be a trick so I am wondering if this would work.
Properly supported of course - do you think its possible to recess a small window air conditioner into the floor with a panel that would cover it when not in use ??? It could even be removed for travel. - properly gasketed and flanged, it could probably seat itself by its own weight if you follow me.
Yes - I'm suggesting that it be installed vertically so to speak. Lift out panel and turn it on - simple. and no worries about air as it sticks out the bottom of the floor. It was a major light bulb on moment.
Possible ??
sdn40
Re: A/C Installation
Postby lopazopy » Sun Feb 17, 2008 9:14 pm
sdn40 wrote:Yes - I'm suggesting that it be installed vertically so to speak.
I'm no expert, but I'm pretty sure you can't install those in a vertical position. They have to be horizontal because of the compressor oil....I think. Do you still have the manual? Might want to check in there about installation.
You can search the forum and find some pretty neat ways of installing the A/C. From installing in the galley (top or bottom) and having it come through the bulkhead wall, to installing it in the front on drawer slides with its own cover.
Hope this helps.
Michael
Cloud 9 here I come!
Seeking professional results with amateur skills.
lopazopy
Images: 21
Postby Miriam C. » Sun Feb 17, 2008 10:02 pm
Happy you found the playground SD. Don't know if you can use those things vertical but you can get air conditioners that blow up. I have one. You can possibly make a rack in the floor so it gets outside air but you will need to vent the return air from the cabin. Probably work best to vent the cool air too.
So about this intro. Who are you and where do you come from. 8) Inquiring minds and noisey Aunti's wanna know all. ;)
Postby Dooner » Tue Feb 19, 2008 8:51 am
:thumbdown: No, not possible. It is not designed to work that way. Lopazopy is right about the oil. That is why, when you tilt any refrigeration device with a compressor, you want to let it sit for a while in the proper position before turning it on.
Dooner.
TED NUGENT FOR PRESIDENT!
Dooner
Images: 69
