by doug hodder » Thu Feb 28, 2008 1:29 am
I'll go out on a limb here...I'd think you could get by with a larger spacing than you are thinking especially if you are going to use a tape also. I'd figure on a pattern that would allow you to attach the sides near the top and bottom and then space the rest using whatever attachment system you decide to use evenly over the rest of the height. 6" ought to be plenty. I can't remember what a Modernistic uses. They do use a close spacing on the roof/wall attachment lip. When you figure in a door and window, on the sides, there isn't large expanses of material that really need to be attached in short increments. A good seal on the rivet on the exterior can be done with aluminum, truck cabs are done like this all the time, but you gotta make it a good riveting job. Stainless is going to be considerably more expensive and in the end be more labor intensive, depending on what you have for tooling.
Others have mentioned floating the skin. Just my opinion, but if you don't have a substrate behind it and only have vertical studs that you aren't attached to, it just might be a problem down the road.
There are any number of ways to attach material, but my opinions are only based on attempting to attach aluminum skin to steel studs. I hope this is of some info and if others disagree...well, have at me. Doug
