Aluminum welding
Aluminum welding
Postby prohandyman » Sat Mar 01, 2008 12:03 pm
I wanting to weld some small aluminuim tubing. But don't own a welder for aluminum. Anyone tried these welding rods? They make it look easy and simple!
http://durafix.com/
Dan
prohandyman
Images: 785
Postby Sonetpro » Sat Mar 01, 2008 12:38 pm
I used it once. I saw it at a boat show and he was demontrating on how you could weld aluminum cans with it. When I got home I quickly realized that is about the only thing you can do with it. Anything thicker it just would not penetrate it like a weld does. JB weld will do the same thing. :thumbdown:
Sonetpro
Images: 107
Postby BigDaddyCool » Sat Mar 01, 2008 12:54 pm
they are crap :thumbdown:
BigDaddyCool
Postby tonyj » Sat Mar 01, 2008 12:59 pm
I tried a similar rod years ago called Aluma-weld, or something like that. Bought 2 pounds of rods. Still have all but 3 of them. I'll be the first to admit that my soldering and welding is about average, but those rods don't penetrate at all. Can't recommend them.
tony
tonyj
Images: 160
Postby reiltear » Sat Mar 01, 2008 2:07 pm
Great question! Even though I'm not an expert welder, I knew that welding aluminum is a bit more involved than Durafix claims.
Here's the description of the proper procedure:
http://www.lincolnelectric.com/knowledge/articles/content/alum.asp
reiltear
Images: 18
Postby kerryd » Sat Mar 01, 2008 2:20 pm
I looked at the Lincoln site . They're give'n the what for on mig welding and the guy in the picture is tig welding . Good info though . Just an observation . Kerry
kerryd
Postby Nitetimes » Sat Mar 01, 2008 7:42 pm
Three very important steps to getting good welds in aluminum
1. Clean it.....
2. Clean it some more....
3. Now, clean it real good....
Stainless steel wire brush is a must!!!
Everything else is secondary to the first 3 steps.
If you have to re-weld it repeat steps 1 thru 3.
:thumbsup: :thumbsup:
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby G-force » Sat Mar 01, 2008 7:54 pm
If the rods you have are similar to what I have seen in the past, they are more of an aluminum solder, braze at best. The only proper ways to weld aluminum are with the MIG or TIG process. It can be oxy-fuel welded, but thats more of an art, and not considered structural. Find a good weldshop familiar with welding aluminum and let them do it.
Mike
Mike
G-force
Images: 22
Postby Art & Pat Burns » Sat Mar 01, 2008 9:14 pm
I used to work for a company that made all aluminum skylights and roof curbs. Everything was Tig welded. The welders told me it is like welding two sticks of butter together.
Art
Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and will preserved body, but rather to skid in sideways, Dunkin Donuts Coffee in one hand, Duffy roll in the other, body thoroughly used up, totally worn out and screaming "WOO HOO, WHAT A RIDE!"
Art & Pat Burns
Postby So-Cal Teardrops » Tue Mar 04, 2008 12:16 pm
A couple more tips from an experienced AL welder:
1. Clean it
2. Clean it real good
3. Clean it some more
So-Cal Teardrops
