by grant whipp » Sun Mar 02, 2008 10:11 pm
BCB!
I'm with Mike & Len ... interior gloss or semi-gloss latex! Since to get a good finish you're going to have to prime & sand before puting down the final paint, anyway, almost any grade plywood will work, but the finer the surface you start with the less work you'll have to put out to get the best result.
A word of warning, if I may, about the use of FRP or plastic laminate in the cabin of your teardrop: IMHO (and those of every painting expert I've talked to), it's O.K. (fine, even) to use on cabint faces and countertops, but ceilings & walls should be left natural, oiled, varnished, or painted. Even with windows and a roof vent, the inside of your trailer needs to breathe, and FRP and plastic laminate don't breathe and only invite moisture to condense on their surfaces ... under extreme conditions, you'll even get condensation on a painted surface, but it will be much less than with the impermeable plastic surfaces. Please leave the plastics to the galley ...
Good Luck on your project, and as always ...
CHEERS!
Grant
Celebrating
Retirement after over
32 Years of Building, Promoting, Supporting, Supplying, Living the Lifestyle, and Loving
Teardrop Trailers!"Life Moves a Little Slower When You're On Teardrop Time"The nature of Life, itself, is change ...
"Those who matter, don't mind, and those who mind, don't matter."
