Page 1 of 1
Doors
PostPosted: Thu Mar 06, 2008 9:53 pm
by alftinc
Getting ready to start my doors on the Cubby. The plans call for a hollow door with framing between the walls. Is there any reasons why one could not just use 3/4 inch ply between the inner and outer skins and just cut the hole for the window??? A solid core door if you will. ??
PostPosted: Thu Mar 06, 2008 10:25 pm
by Gage
No problem whats so ever. Either or. What ever is easy for you.
PostPosted: Thu Mar 06, 2008 11:22 pm
by G-force
Other than the extra weight, it will work. Why not make it hollow with insulation?
PostPosted: Fri Mar 07, 2008 6:12 am
by toypusher
You may (may) get condensation on the door without the insulation in it and it will be alot heavier, but not unreasonably heavy. Also, the door will not be even with the inner sidewalls either and you may have some problems (or difficulties) getting your latch setup on and working they way you want it to.
