floor waterproofing???
Postby urbanironaz » Fri Mar 07, 2008 7:15 pm
has anyone tried to put a rubber shower liner or pond liner between the trailer frame and the plywood floor ??? :thinking:
urbanironaz
Images: 11
Postby satch » Fri Mar 07, 2008 7:44 pm
Sounds like it would work, but why?. Roof tar would work just fine, and is a fraction of the cost. 8)
If it itches. scratch it
Rick
satch
Images: 63
Re: floor waterproofing???
Postby Dee Bee » Fri Mar 07, 2008 8:38 pm
urbanironaz wrote:has anyone tried to put a rubber shower liner or pond liner between the trailer frame and the plywood floor ??? :thinking:
In my view a vapor barrier like you are suggesting will promote rot if any moisture gets trapped between the rubber and the wood. For this reason I think a spray on or paint on coating or tar iwill serve better.
Dee Bee
Grace happens...
Dee Bee
Images: 55
Postby Steve_Cox » Fri Mar 07, 2008 9:31 pm
A lot of travel trailer manufacturers wrap their plywood floor in a sheet of nylon reinforced plastic. I have found that it is a great place to trap water in the few trailers I have had experience with. Leaky doors or windows, the water gets trapped in the plastic sheet under the floor. Leaking sink or shower drains, again the plastic sheet can catch and hold the water. It always leads to the floor delaminating. I like the way most tear droppers do it better. Some use epoxy, others use a roof coating, while some just use paint. My plywood floor was encapsulated in epoxy.
Steve_Cox
Images: 196
Postby doug hodder » Fri Mar 07, 2008 9:45 pm
Like others mentioned, it's a great water trap. You live in AZ...I wouldn't worry about it. I'm in No. Cal. I just use a good quality oil based primer and paint. Others may disagree, but it works for me. Doug
Postby TPMcGinty » Fri Mar 07, 2008 10:12 pm
I didn't want all that gooey roofing tar on the bottom of my trailer so I am coating it with an asphalt based fence post paint. It smells like asphalt when painted on but once it dries the smell goes away. Best of all it dries hard.
Tim
TPMcGinty
Images: 146
Postby GPW » Sat Mar 08, 2008 6:54 am
We sealed our TD (waterproofed) with our favorite mixture of 25% Polyurethane and 75% mineral spirits... a couple coats really sinks in and seals the ply/lumber...cheap and quick too ... Still use the tar stuff on the bottom though... :thumbsup:
Postby Dee Bee » Sat Mar 08, 2008 10:49 am
I used automotive spray undercoating 5 spray cans was all it took. Quick and neat.
http://www.nfdc.net/home/cbdb/Teardrop%20Deck.htm
Dee Bee
Grace happens...
Dee Bee
Images: 55
