Page 1 of 1
How to Weigh Teardrop at Home
Posted:
Tue Feb 15, 2005 4:26 pm
by James (tinbender)
Does anyone know how to weigh your tear at home maybe with home scales?
Posted:
Tue Feb 15, 2005 4:30 pm
by SteveH
I've weighed my tongue weight with bathroom scales, but I don't know how to weigh the whole thing because even one wheel at a time should be too heavy for the scales. They only go to 300 pounds.
Posted:
Tue Feb 15, 2005 5:31 pm
by john
Try puting one end of a 2x6 on the scale. Pull the trailer up the the "ramp" half way. The scale should read half the weight. If it is still too much pull the trailer a quarter up the "ramp". Multiply the result by 4. Worked for me.
john
Posted:
Tue Feb 15, 2005 9:34 pm
by Ken
It would be a lot cheaper to take the trailer to a junk yard, scrap metal reseller or most any truckline or state dps office and get info on where to get weighed. If you really want to do it yourself, estimate the weight, say 1500 lbs. Bathroom scales go up to 300 lbs, go to Wal-Mart and buy 6 scales, total capacity 1800 lbs. Now figure how to jack up the teardrop and keep it fairly level, slip the scales under at equally distributed points, place braces or legs between the teardrop and the scales, lower the tear drop down and add up the total scale weights, now jack the teardrop up, subtract the weight of the legs or braces you placed between frame the scales. Again, a lot cheaper and easier to go to the public scales.
Posted:
Tue Feb 15, 2005 9:54 pm
by Mark Mckeeman
Hi,
John's got the right idea. Just borrow a couple of scales so you have three. Make a block for one end of the 2x6 so the pressure is applied to the center of the scale. Make it easy and use a 4 foot board with a line accross it in the middle. With the center of the wheel on the two foot line multiply the scale readig by 2. Add up all three scale readings and you got it.
I've weighted aircraft with this same method. Worked for me .... I havn't crashed.....yet!
Posted:
Tue Feb 15, 2005 11:39 pm
by DANL
I just took mine to the local gravel/stone dealer and drove it onto the scale. Drive off, disconnect the trailer and drive back onto the scale, subtract the vehicle only weight from the combination weight and there you have it.
Cost: $6.00.
Any place that sells or buys sand/gravel/stone/steel/iron/etcetera by weight should have a drive-on scale.
Posted:
Tue Feb 15, 2005 11:46 pm
by steve wolverton
DANL wrote:I just took mine to the local gravel/stone dealer and drove it onto the scale.
And how much did it weigh?
Posted:
Tue Feb 15, 2005 11:49 pm
by asianflava
john wrote:Try puting one end of a 2x6 on the scale. Pull the trailer up the the "ramp" half way. The scale should read half the weight. If it is still too much pull the trailer a quarter up the "ramp". Multiply the result by 4. Worked for me.
john
This method works, I've read how people adjust their corner weights like this.
Posted:
Wed Feb 16, 2005 12:38 am
by Denny Unfried
So, how many stone did it weigh? Maybe Andrew could convert.
Denny
Posted:
Wed Feb 16, 2005 1:28 am
by steve wolverton
asianflava wrote:This method works, I've read how people adjust their corner weights like this.
*sigh* I don't know why I never thought about doing that. I just pulled mine up on the scale and weighed it. It's loaded with camping gear, bedding, and ready to go - 467 pounds. wOOt!
Posted:
Wed Feb 16, 2005 1:31 am
by asianflava
steve wolverton wrote:[*sigh* I don't know why I never thought about doing that. I just pulled mine up on the scale and weighed it. It's loaded with camping gear, bedding, and ready to go - 467 pounds. wOOt!
Shouldn't that be Moo?
Posted:
Wed Feb 16, 2005 9:08 am
by DANL
About 970 pounds fully stocked. I figure about 1050 to 1100 with bikes, cooler, and other sports gear thrown in. Not a lightweight but then it is very solidly built.
Posted:
Wed Feb 16, 2005 4:06 pm
Has anyone weighed a cubby?
Posted:
Wed Feb 16, 2005 7:24 pm
by mikeschn
James (tinbender) wrote:Has anyone weighed a cubby?
My first Benroy which is very similar to a Cubby, weighed 840 lbs.
