What Length
What Length
Postby Tombstonebilly » Fri Mar 14, 2008 11:03 am
:thinking: Does anyone what the total length from bottom front across top to bottom rear on a 4x8 Gen.Benroy ?
Be The Person Your Dog Thinks You Are !
Tombstonebilly
Re: What Length
Postby lopazopy » Fri Mar 14, 2008 11:52 am
Tombstonebilly wrote: :thinking:
Yep, that about sums it up.
Michael
Cloud 9 here I come!
Seeking professional results with amateur skills.
lopazopy
Images: 21
Postby reiltear » Fri Mar 14, 2008 2:03 pm
My rough estimate is 14' 1-3/4". "Rough" because I made an assumption that the hatch is a full 48" radius quarter-arc, instead of 2(48", 19") and a straight 18-1/4" section at the bottom.
If you get 4 4'X8' sheets for exterior and interior skinning there should be enough plywood(if that's what you'll be using) left for about 2/3rds of interior and galley cabinet door panels(some 1'-by would still be required for either frames or slide rails)
reiltear
Images: 18
