deacon328 wrote:Bassman, I would like to second your question! I too have read that you should move the axle back, especially with the Harbor Freight 4 X 8 that I have.
Does it also depend on what KIND of tear you are building? Mine will be light and just a basic tear with hardly anything in the galley.
Is the axle move for all trailers?
G-force wrote:In general, you want 10% of the total weight on the hitch. The less weight you have on the hitch, them less stable the trailer is in towing. They tend to sway more and track will less control. Granted this is at typicly highway speeds, I assume you Moris will be towing at a much reduces speed which will help. For such a small car with such a small motor, I would build the lightest trailer you can and keep the hitch weight at 8% or so.
chorizon wrote:The 12mm should be fine for the floor as well as the walls. The 15mm is not necessary. That being said, most people would insulate the floor and walls. The iron you're allocating for your frame is perfectly adequate. As far as the HF trailer, how do I say this? Is there a supplier of say, cheaper than usual hardware/tools that happens to be made in China in the UK? If so, they would be an excellent choice to explore a pre-fabbed trailer at cheaper than 200+ quid, if they were an HF equivalent.
angib wrote:Phil, if you've found a bolt-together trailer kit in Britain for GBP230 (where from?), you're doing well - I've only seen the 1100lb 8 inch wheel version in Northern Tool UK for GBP 305 incl VAT - Merkans look away now, as that is $610!
Your Moggie will want a light trailer weight for both starting and stopping, but I don't think hitch weight will be too much problem - those leaf springs on the rear of a Moggie are quite stiff by comparison with modern vehicles.
You also are getting US advice from this forum on recommended nose weights and you should be aware that virtually all trailers in Europe would be considered dangerous in the US because we run with such low hitch weights: 5-7% of total trailer weight on the hitch is considered perfectly reasonable here and many tow cars are limited to 4% hitch weight at their maximum tow rating.
If you get a bolt-together trailer, you will probably find that the stock axle position suits you fine, unless you were planning a very heavy galley (which the Moggie couldn't pull anyway...). The one thing to watch out for is that with the axle near the middle, it can be a squeeze to fit the doors in front of the mudguards [fenders].
Andrew
PS There's my (former) Moggie:
