Toytaco2
I used just an RV window to make my doors.
I did have a member ask me about my doors today and I tried to explain what I used in another topic on this great forum it is on the bottom of pg.2
http://tnttt.com/viewto ... c&start=15 )
Or you can check out my construction page on my site.
http://vegasteardrop.com/TD_and_Misc_Const_.html )
But what I understand is that you want to put RV windows in an existing door.
If this is correct you should be able to do this, I do not know how the door that you plan to use is constructed, But most likely long as you leave 4 or 5" around the RV window I do not see any problems, You may have to make sure that the hinges that hold the door are substancial enough to accomodate the window. ( Most RV windows are not very heavy do to most of them are made out of aluminum. )
I know that there are many people within this great forum that have done the same thing that you are continplateing on doing and they will be responding to your post real soon.
Good luck keep us informed of your progress.
And anyone out there building a TD is more then welcome to check out my Construction page on my website & remember take what you want & leave the rest.(New TD Build Has Begun)
The Sin City Teardropper.
Ken F.
www.VegasTeardrop.com )
