I've tried using flux cored wire, but as expected find it somewhat impossible to see where I'm welding & what is happening. IE I cannot see the metal melting
Today I bought some solid Telwin wire to try with Co2. The wire looks like copper & is built like a spring. Yes A SPRING. Which is the problem
There's no way to hold the wire spool in place using anything supplied by Telwin. The only thing I can think of is placing a couple of washers around the spool, so that the Telwin spring applies some tension to it. Rather than to the air it normally tensions
Any thoughts, advice etc etc etc ?
tia
david
