by doug hodder » Fri Feb 18, 2005 10:53 pm
Dave, there are primers that can be applied without etching, if painting, you can get away with a quick sand, wipe down with lacquer thinner and shoot primer then paint, acid etching is necessary if not doing any other prep work. I've shot lots of fire fighting equipment (trucks) this way. If you're not going to sand, yes you do need to etch. I can only speak from experience in drier climates, like Colorado. I'm sure that the paint suppliers in more wet areas might have other suggestions. For me, I don't want to have to use an etch on top of my scuff finish as I don't want to take away from any of the brilliance of the scuff. Painting aluminum and clear coating aluminum are apples and oranges. Etches that I have used in the past created a dull finish, and marine environments are a whole 'nother critter, especially salt water... I'm still trying to find out the correct combination for what I'm trying to achieve, If I screw it up, I'll strip it and do something else. Finishes have changed in recent years and I'm drawing on experience that goes back 20 so it was long long ago on a planet far far away. doug hodder
