Do flat roofs on teardrops usually, or often, sag? If so how can this sag be avoided? I've seen two teardrops locally with flat roofs. They both sag about a half inch or so in the middle. It could create a water ponding area and make the roofs more prone to leaks. Is this typical for a flat roofed teardrop?
One builder said he used stout roof rafters. Both are 5 ft. wide. One is skinned with plywood and epoxy. The other is skinned with aluminum over plywood.
I'm starting the construction of my teardrop. I'm concerned because my Grumman II inspired profile is almost flat for about 3 feet above the sleeping area. This part of the roof has about a 1/4" per foot, front to back, taper. If it'd help to keep the roof from sagging I can taper it a little more from the center of the roof to the front. The back part of the roof tapers more and will have support from cabinets and the partition wall between the galley and sleeping area. So it worries me less.
I plan to build the roof with 1-1/2" high roof spars on 1' centers. I may also put blocking in between the roof spars along the center of the roof hoping that will stiffen it.
Currently I have a 5'x10' trailer frame and just cut out a side profile pattern from 1/2" plywood. I'm going to begin building the floor today. The teardrop will be about 5'3" wide by about 11' long. I don't want my trailer to have a saggy roof.
