I need help.. I mean the Voyager needs help..
The last rib across where the hinge is supposed to sit wobbles and it was too far for the very nice Better Than Hurricane Hinge from Grant..so I had to take it apart.
1st question - what is the best way of securely fastening the rib to the walls? Looks like my way failed..
2 the rib was too far towards the front to set the hinge properly..
Also should that rib be narrower than what the hatch edge is where the other half of hinge should be installed? or is it ok if they are the same size? Ive got that rib totally out now since I have to redo it..
3 - What is the proper procedure for installing this hinge once I get the rib problem fixed..
I see Grant has some sort of markings on the Hinge however not sure if they are for the cutting of it or was it his markings.. Maybe Grant will stop on in to this thread..
All was going too well I say.. to be true..
I will grab some pics so it will define the problem better..
Classic Finn
PS Garsh I wish I was closer to someone that could come and assist in solving this..
