Hatch Seal Method
Hatch Seal Method
Postby Toytaco2 » Thu Apr 03, 2008 3:58 pm
I plan to dry fit my walls, mark and drill all the spar locations and the bulkhead locations this weekend. Afterwards, I’ll disassemble everything and insulate the walls and attach the interior wall skins – And—cut out the “dreaded hatch notch”. Thanks to all the great help on this forum, I think everything should go well. But, I confess I’ve never even seen a finished teardrop except the photos on this board. So I’m a little fuzzy on the best way to seal the hatch (let alone the doors which will come later). I could use some opinions:
Is it better to cut the full 3/8” notch out of the side walls (as in Generic Benroy plans) or use my router and cut a sort of rabbit on the outside edge where the hatch will meet the side walls, something like ½ inch wide x ¼ or 3/8” deep for the weather stripping? It seems like the router approach leaving a “hard lip” next to the galley would be the easiest to do and perhaps the most efficient, but, I have no experience to go by. I can do it either way, but, would like some thoughts on the best and most leak proof way to go. BTW my walls are 1/4" outer skin, 3/4" framing and 1/8" interior sandwich style construction.
Thanks,
Mike
Toytaco2
Images: 368
Postby mikeschn » Thu Apr 03, 2008 7:27 pm
I know what you're asking, but it's late and I'm tired... and I don't have the Lil Diner and the Benroy sitting in the driveway to look at... :cry:
But let me dust off the old cobwebs...
Look at this pic... the black stripe under the hatch is the weather stripping. It is 3/4" wide. And it sits on the plywood walls, which are also 3/4" wide.
If you were to route out a rabbit, let's say you made it 3/8 x 3/8. It would work, as long as you used insulation that was say, perhaps, 1/2" thick. That way you could compress it for your sealing effect.
I don't think you'll gain much unless you build a hatch, like was on the Lil Diner...
But as you can see that is quite a bit more complicated. You might want to get Steve Fredericks manual to help you with that if you decide to go that route.
Postby boomboomtulum » Thu Apr 03, 2008 9:16 pm
I cut this with a router. and now have it epoxied to make it stronger and waterproof. I plan as you can see on placing the weather strip on the flat area any water will run to the outside at the bottom.
Dave
http://www.mikenchell.com/forums/album_ ... c_id=37109
Have'nt been everywhere yet, but it's on my list.
boomboomtulum
Images: 50
Postby jplock » Thu Apr 03, 2008 10:05 pm
This method has worked good for me so far.
Slots routed out for 3/8" weatherstrip
Application of weatherstrip
Finished product
Hatch was hung on hurricane hinge from Grant Whipp
jplock
Keep smiling!
jplock
Images: 233
Postby Airspeed » Fri Apr 04, 2008 8:00 pm
I used some rubber coated steel U channel I got from McMaster Carr, it worked great and gave the edge a nice finished look. It just caps the edge of the plywood and when I close my hatch the aluminum trim fits against it nice and snug. I haven't driven it in the rain but I did test it with the pressure sprayer at the car wash and it didnt leak a drop. They also have the same trim with a bulb gasket on the top or side
Airspeed
Images: 16
Postby Creamcracker » Sat Apr 05, 2008 4:14 am
Airspeed wrote:I used some rubber coated steel U channel I got from McMaster Carr, it worked great and gave the edge a nice finished look. It just caps the edge of the plywood and when I close my hatch the aluminum trim fits against it nice and snug. I haven't driven it in the rain but I did test it with the pressure sprayer at the car wash and it didnt leak a drop. They also have the same trim with a bulb gasket on the top or side
Did you notch the side walls before fitting the U gasket? If so how deep a notch?
Philip
Creamcracker
Teardrop Graduate
Images: 142
Postby Airspeed » Sat Apr 05, 2008 6:44 am
I notched the top edge down about 1/4", the thickness of the trim, when I close the hatch it seals so tight that I can hear air rushing out and the air cushions the hatch as it closes.
Aaron
Airspeed
Images: 16
Postby jplock » Sun Apr 06, 2008 6:06 pm
If memory serves me it was about 1/4" deep and about 3/8" wide slot, and the trim was 3/8"x 3/8" with adhesive backing on the weatherstrip.
jplock
Keep smiling!
jplock
Images: 233
