If its good: It starts curing in 30 minutes and is hard overnight.
My bad tube had not "started" curing 4 hours later. Next day I could split the glue seam with a light hammer tap.
From now on I'm going to test each tube of whatever I buy FIRST!
Airspeed wrote:You should try TiteBond II, It is far superior to PL and theres no need to test it! As long as it comes out of the tube it's good. Aaron
Using the lot code you gave previously, 03249, here is how you would interpret it:
- the '03' is the last two digits of the year of manufactuer, this case being 2003
- the 249 is the 249th day of the year out of 365.
- our products have a one year shelf life from this date of manufacture.
Toytaco2 wrote:Anyway, I checked the code dates, and found one of the tubes to be #03005 and the other to be #03016. I bought them in late February of this year. If they gave you the correct method for decoding, then HD is selling 5 year old glue as well.
