best wood for replacing floor
Postby alloffroad » Fri May 09, 2008 10:11 pm
I must replace the floor in the camper. Can I use regular plywood and water seal it or is marine ply needed? What is used be the manufacturers on new rigs?
alloffroad
Images: 7
Postby madjack » Fri May 09, 2008 10:37 pm
...use a regular grade of ply and seal well...unless it specifically states it is for indoor use only, you should be good to go...marine ply for anything butta boat issa waste (IMNSHO).........
