Page 1 of 1
best wood for replacing floor
PostPosted: Fri May 09, 2008 10:11 pm
by alloffroad
I must replace the floor in the camper. Can I use regular plywood and water seal it or is marine ply needed? What is used be the manufacturers on new rigs?
PostPosted: Fri May 09, 2008 10:37 pm
by madjack
...use a regular grade of ply and seal well...unless it specifically states it is for indoor use only, you should be good to go...marine ply for anything butta boat issa waste (IMNSHO).........
madjack 8)
