by doug hodder » Thu Feb 24, 2005 1:37 am
Guy, I spoke to the people at Gougeon bros, the manufacturers of West System epoxy, and they told me that the #207 special hardener will provide the necessary protection. They specialize in boat finishes. On top of that, automotive clear coat also adds to the protection. Anilin dye on it's own is not uv stable, it has to have some protection, as do most dyes and stains. According to the information at woodworkers supply, "anilin dyes should never be used for exterior applications... and that water based anilin dyes provide the most light fast colors. Applying a clear topcoat with UV protective additives will extend the life of any dye color." I am using 3-4 coats of UV protective epoxy, with 2 coats of auto clear coat which adds to it. I haven't had a problem yet with it on my boats. For me, and I'm using epoxies, you can't use an oil based stain/dye as it will alter the bond between the epoxy and the wood, and alcohol based stains fade quicker, so the water based dye was the answer for me. Also you get the most intense color using a dye as opposed to a stain. On the top of my boat, using 2 different color dyes under epoxy and clear coat, I can regularly get 10 degrees difference in temperatures from the red to the dark walnut. Nothing has separated yet and the color is holding. I can only speak from my experience, and I may be sorry down the road, but it's too late now. We'll see. I look at it this way, 6 years from now I may be tired of the color and will sand/grind it all off and redo it. I think right now it beats the annual maintenance of varnish. Just my opinion. doug hodder PS I hope that I didn't offend any varnish people....
