by grant whipp » Fri May 16, 2008 11:51 am
Hi, Noni!
Another possibility would be to line the walls & ceiling with the padded & pre-patterned upholstery material found in many upholstery supply shops (some looks like tuck-n-roll, some looks like diamond-tuck, etc.). It doesn't take much padding to make a big insulative difference, and the added bonus is that it will give the trailer a much nicer feeling inside.
Don't know if you've looked at the Bell RV Liberty yet or not, but their trailers have insulation laminated into the structure as well as a thin layer of insulation under the headliner material.
Good Luck with your search! In the meantime ...
CHEERS!
Grant
Celebrating
Retirement after over
32 Years of Building, Promoting, Supporting, Supplying, Living the Lifestyle, and Loving
Teardrop Trailers!"Life Moves a Little Slower When You're On Teardrop Time"The nature of Life, itself, is change ...
"Those who matter, don't mind, and those who mind, don't matter."
