mikeschn wrote:... the 4 bolt HF wheels are 4 on a 100mm B.C.
http://tnttt.com/viewto ... cle#179440
teardropty wrote:...Is my logic correct that I can get a different hub/bearing/rim setup as long as the inside diameter of the hub/bearings is the same as the axle spindle? I too am leary about putting too much faith in the HF hubs and bearings. I have been looking at better quality marine grade hubs that would give me a 5 bolt (and therefore better selection of rims,etc.) and just putting those on the existing HF axle spindles.
madprinter wrote:I used a Dexter axle on my trailer. I mounted FORD Explorer 14" rims on the hubs. The bolt pattern was the same ,but the center hole was slightly smaller. I enlarged it with a rotory rasp on a drill. The aluminum cut away quickly and it only took a few minutes and turned out uniform. Keep this in mind when looking at rims. Bolt patern AND center hole size.
Good luck, William
