My question is, should I remove the staples or set them and fill any depressions with Fill-It? Will they work out over time and cause problems if left in place?:thinking:
tk/Tom wrote:What Dave said. Those kind of staples (air gun) are resin coated. When they are driven, the resin is heated and melted by the friction and sets up when it cools. If you can pull them without absolutely destroying whatever they are holding together, you're a modern marvel. Arrow T-50 staples have no resin. If that's what you used and you aren't putting something like fiberglass resin over the top, then they best be pulled.
