Propane line type
Propane line type
Postby boomboomtulum » Wed Jun 04, 2008 9:13 pm
Last thing on the build. I have a 1959 2.5 lbs LP bottle mounted on the tongue. What is the best method of routing lines to the stove? Soft copper? 3/8 pipe? 1/2 copper or what?
Dave
http://www.mikenchell.com/forums/album_ ... c_id=37109
Have'nt been everywhere yet, but it's on my list.
boomboomtulum
Images: 50
Postby del » Wed Jun 04, 2008 9:32 pm
I used 3/8 copper tubing. Had to flare the ends to be safe with propane.
del
del
5000 Club
5000 Club
Images: 410
Postby Sonetpro » Wed Jun 04, 2008 9:33 pm
I used a 12' extension hose from Coleman. It runs along the frame held by clamps that have rubber in them so they won't chafe.
All of my connections are made outside the trailer. I ran the feed from the stove through the bottom and made the connection underneath.
It you have a 1959 bottle I doubt that they will fill it unless it has been upraded with the new saftey valve.
The extension hose made it easy since the ends were already on it.
Sonetpro
Images: 107
Postby sdtripper2 » Wed Jun 04, 2008 10:53 pm
Dave:
Try these threads:
Hose/ connection to the rear from front of trailer
http://tnttt.com/viewtopic.php?p=181197
Propane Plumbing
http://tnttt.com/viewtopic.php?t=7241
http://tnttt.com/viewtopic.php?t=8837
Fittings quick disconnect
http://www.teecoproducts.com/Catalog/M3.htm
sdtripper2
Search Garoux
Images: 168
Postby brian_bp » Thu Jun 05, 2008 1:31 pm
Good idea, Steve: this is not a new subject.
Now a couple of comments specifically about the options suggested in this thread (which happen to be quite opposite of each other):
I would not use solid metallic (copper) line all the way to the removable tank, even with the spiral in it. I don't have ready access to any of the federal or provincial/state gas codes, but I doubt this is allowed... a hose is called for.
On the other hand, hose for the whole run also seems like an undesirable plan. I would expect hose to degrade with time much more than metal pipe, so I wouldn't want a run of it hidden, especially under the trailer getting pummeled by road debris. It's also a pain to support properly.
I think the best way to go is to use the right material for each section (tank connection, under trailer, up to appliance), as described in those posts.
Same links with thread/page titles:
Propane: What kind of pipe is recommended?
Propane Plumbing
propane plumbing
propane hose
Camping Equipment - Quick Disconnect Couplings,Camping Appliance Tees, Extend-A-stay
brian_bp
Images: 9
Postby boomboomtulum » Thu Jun 05, 2008 6:45 pm
Great thanks for all the suggestions. Back to OSH for more parts.
Dave
boomboomtulum
Images: 50
