Page 1 of 1
Propane line type
PostPosted: Wed Jun 04, 2008 9:13 pm
by boomboomtulum
Last thing on the build. I have a 1959 2.5 lbs LP bottle mounted on the tongue. What is the best method of routing lines to the stove? Soft copper? 3/8 pipe? 1/2 copper or what?
Dave
PostPosted: Wed Jun 04, 2008 9:32 pm
by del
I used 3/8 copper tubing. Had to flare the ends to be safe with propane.
del
PostPosted: Wed Jun 04, 2008 9:33 pm
by Sonetpro
I used a 12' extension hose from Coleman. It runs along the frame held by clamps that have rubber in them so they won't chafe.
All of my connections are made outside the trailer. I ran the feed from the stove through the bottom and made the connection underneath.
It you have a 1959 bottle I doubt that they will fill it unless it has been upraded with the new saftey valve.
The extension hose made it easy since the ends were already on it.
PostPosted: Wed Jun 04, 2008 10:53 pm
by sdtripper2
Dave:
Try these threads:
Hose/ connection to the rear from front of trailer
http://tnttt.com/viewtopic.php?p=181197
Propane Plumbing
http://tnttt.com/viewtopic.php?t=7241
http://tnttt.com/viewtopic.php?t=8837
Fittings quick disconnect
http://www.teecoproducts.com/Catalog/M3.htm
PostPosted: Thu Jun 05, 2008 1:31 pm
by brian_bp
Good idea, Steve: this is not a new subject.
Now a couple of comments specifically about the options suggested in this thread (which happen to be quite opposite of each other):
I would not use solid metallic (copper) line all the way to the removable tank, even with the spiral in it. I don't have ready access to any of the federal or provincial/state gas codes, but I doubt this is allowed... a hose is called for.
On the other hand, hose for the whole run also seems like an undesirable plan. I would expect hose to degrade with time much more than metal pipe, so I wouldn't want a run of it hidden, especially under the trailer getting pummeled by road debris. It's also a pain to support properly.
I think the best way to go is to use the right material for each section (tank connection, under trailer, up to appliance), as described in those posts.
Same links with thread/page titles:
Propane: What kind of pipe is recommended?
Propane Plumbing
propane plumbing
propane hose
Camping Equipment - Quick Disconnect Couplings,Camping Appliance Tees, Extend-A-stay
PostPosted: Thu Jun 05, 2008 6:45 pm
by boomboomtulum
Great thanks for all the suggestions. Back to OSH for more parts.
Dave
