I had a thought today while at the hardware store. What if I used 3/4" galvanized pipe instead of a galley hinge? I could mount the 54" long pipe horizontally into flanges mounted on the side walls and drill through a super-reinforced hatch with bushings or bearings mounted every 16" or so on struts. Placing the 3/4" pipe as close to the top of the hatch would be essential so that the tail (the part that goes down when the hatch goes up)is as small as possible. A counterbalance system could even be derived to help with the lift. As far as sealing the top. I'd just overlap any gap with 1/8" plywood so that the tail swings up and makes positive contact. Trunk latches would also help swing it upward.
If the weakness of some tears is the hinge, its potential for water intrusion and the great stress put on a concentrated area, why wouldn't this idea work?
Drawing to come.
