Undercoating
Undercoating
Postby Rockguy » Fri Jun 20, 2008 2:50 pm
I see most everyone uses roofing tar for the underside of the floor. Has anyone used the spray undercoating, pro's, cons?
Rockguy
Postby madjack » Fri Jun 20, 2008 3:40 pm
... a partner of mine used it...it looked like it did a fine job...however, he later(1yr) decided to change axles and when he pulled the frame loose, the undercoating came off with it...even though it was dry when he put the body on the frame, it stuck better to the frame than it did to the wood...the wood looked unaffected by the enviorment...take that for what it's worth..he used a spray undercoat he bought from NAPA...don't know the actual brand name...I usually coat with urethane or epoxy but have been considering the "asphalt fence post" paint.......
Postby TPMcGinty » Fri Jun 20, 2008 5:29 pm
madjack wrote:...I usually coat with urethane or epoxy but have been considering the "asphalt fence post" paint.......
The asphalt based fence post paint is supposed to work on both metal and wood.
Tim
TPMcGinty
Images: 146
Postby madjack » Fri Jun 20, 2008 5:36 pm
...that is why I have been considering it...................... 8)
Postby kate » Sat Jun 21, 2008 11:50 am
I am planning to use sheets of Grace Bituthene. It is a sticky, rubbery substance used in coating foundation walls in home construction. I'll let you know how it goes. I hope to get it done today.
kate
Re: Undercoating
Postby Dee Bee » Sun Jun 22, 2008 12:37 pm
Rockguy wrote:I see most everyone uses roofing tar for the underside of the floor. Has anyone used the spray undercoating, pro's, cons?
I used spray automotice undercoating in aerosol cans. A few cans did a good job. After three years, so far so good. It seems lighter than asphalt, too
http://www.nfdc.net/home/cbdb/Teardrop%20Deck.htm
Dee Bee
Grace happens...
Dee Bee
Images: 55
Postby swissarmygirl » Sun Jun 22, 2008 12:46 pm
I used the spray stuff. Killed more than a few brain cells in that process, I'm sure. There are some really great warnings on the can! :?
I think it took me 3 cans to cover my 5' x 8'.
We're not on the road yet, so can't tell you how its holding up. :thinking:
"Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it." - Mark Twain
"The intuitive mind is a sacred gift and the rational mind is a faithful servant. We have created a society that honors the servant and has forgotten the gift." - Albert Einstein
4 Hats Studio
swissarmygirl
Images: 129
Postby Creamcracker » Sun Jun 22, 2008 3:23 pm
I also used automotive undercoat spray.
Philip
Creamcracker
Teardrop Graduate
Images: 142
Postby chrlshrdy » Tue Jul 01, 2008 2:44 pm
Has anyone used a spray in bed liner for their undercoating? There is one I found called "Speedliner" that touts that it can be applied to metal, wood, or concrete. It also has a Kevlar additive.
http://www.speedliner.com
chrlshrdy
Postby Jst83 » Tue Jul 01, 2008 3:44 pm
You're supposed to undercoat them :thinking:
:lol:
Jst83
Images: 215
Postby BPFox » Tue Jul 01, 2008 4:09 pm
Jst83 wrote:You're supposed to undercoat them :thinking:
:lol:
I get a lot of flack for this but I wouldn't. I have built two trailers in the past. One got undercoated and one didn't. On the one that got undercoated, the plywood floor rotted out in about 6 years. The other one, the one without the undercoating is still going strong after 15 years. Now these are not camping trailers, but based on personal results, I wouldn't recommend the undercoating. Buy good plywood and let it breath. No trapped moisture, no rot. Just one man's opinion and I'm sure I am in the minority. Such is life. Peace.
BPFox
Postby Jst83 » Tue Jul 01, 2008 4:43 pm
BPFox wrote:I wouldn't recommend the undercoating. Buy good plywood and let it breath. No trapped moisture, no rot. Just one man's opinion and I'm sure I am in the minority. Such is life. Peace.
My thoughts exactly
I'll admit I really didn't undercoat, I was thinking the same thing back when I started. I've thought about lifting it and undercoating it just haven't got to it yet.
I've got 2 years and over 2,000 miles on it with no problems yet.
So I guess we'll be in the minority together.
I wonder if others have bypassed the undercoating?
Jst83
Images: 215
Postby Lgboro » Tue Jul 01, 2008 5:51 pm
A long time local RV dealer suggest that I use the mesh like material
almost all of the RV use to protect the bottom of their RVs. He is like the
Fred Sandford of RV dealers and keeps a bunch of used RV parts along
with most new parts. I am planning on buying a used piece of this
material that he claims will allow the floor to breathe while protecting from
damage. So far his advice has been backed up by my brother and others
in the RV industry. He has years of experience with conversions and
building horse trailers, etc. as well as campers.
Lgboro
Images: 53
Postby ArtMini » Tue Jul 01, 2008 8:25 pm
I just bought roofing cement today, hope to under coat my floor before putting it on then maybe another coat after its on, what do you think? I saw some one used roofing cement on here.
Art
Lgboro wrote:A long time local RV dealer suggest that I use the mesh like material
HAVE FUN STORMING THE CASTLE!!!!
ArtMini
Images: 16
Postby sid » Tue Jul 01, 2008 8:44 pm
That's what Yoder Toter used on the Silver Shadow we owned. Seemed to work okay.
sid n side
"If you're going through hell, keep going......" Winston Churchhill
Side by Side - completed October 2008
sid
Images: 194
