Window/door construction
Postby johnp » Tue Mar 01, 2005 7:38 pm
i see the assie tears have a door thats all window, where does one get these?
sorry if im drivin ya all nuts
johnp
A weekend alone,,,,,,
Full gas tank.
Stopping at a stopsign, and askin what direction?
Wifes response---I dont care,,,
Finding an old dirt trail to nowhere,,,
priceless,,,,,
johnp
Images: 5
Postby Boodro » Tue Mar 01, 2005 11:19 pm
Hi John , I was just wondering what an " assie" is? :roll:
Also when is a door , not a window? :roll: :roll:
Have fun! :D
We are all travelers in this world , from the sweet grass to the packin house , birth till death , we travel between the eternities . ( Robert Duvall as Prentiss Ritter)
Boodro
Images: 101
Postby mikeschn » Wed Mar 02, 2005 3:05 am
I'm sure Reiner would sell you a door that looks like a window... it's just that Australia is so far away, that the shipping costs would be rather high.
Boodro... In the hall of fame click on Reiners World Famous Teardrops...
or go here...
http://www.aussieteardrops.com/
Postby len19070 » Wed Mar 02, 2005 5:41 am
John
I have made these window/doors before. They are actually a very good way to go. Get a window from All-Rite http://www.all-rite.com/ (verticle slider.) There custom made so you can get any size you want. Mount a Heavy Duty aluminum piano hinge (alum to alum, don't mix metals) to one side of the window. Theres your door. Using the door as a pattern cut the door opening 1/4" larger (all around) than the inside mounting flange. You will have to cut a slot into the mounting flange on the door to accept a strike/keeper opposit the hinge side.
http://www.rvlifestyles.net/Parts.aspx? ... 2003730023
for a "T" handel (avail at home depot) MOUNTED ON THE BODY___NOT THE DOOR. Put some kind of weather strip around the outside of the door and your done. The only draw back to this kind of door is that the slider is at the bottom. And your bedding will cut a lot of the airflow. Mounting the door slightly higher will help...but not to high. To high could have you singing Soprano...trust me, I know.
Happy Trails
Len
len19070
Images: 24
