Water holding tank hoses?
Postby Efiladeeni » Sat Jun 28, 2008 8:33 am
I destroyed my popup and kept all the parts to use in my teardrop. My question is what are the two hoses from the water storage tank for? One goes to the pump faucet...the other goes where? does anyone know?
Every wish you had taken pictures BEFORE you took things apart???
Thanks for any help!
Erin
Efiladeeni
Postby closurdo » Sat Jun 28, 2008 9:30 am
Assuming that you're not talking about the fill hose the tank should have a small diameter hose fitting near the top of the tank to vent it.
If you look at this link: http://www.campingworld.com/browse/skus/index.cfm?skunum=16248&src=SRQB you will see a fresh water fill that has a connection for the fresh water tank (large hose) and above it (small hose) the connection for the tank vent hose.
closurdo
Postby Efiladeeni » Sun Jun 29, 2008 6:06 am
Thank you so much! I just couldn't figure it out, but it makes sense the tank would need to vent somewhere! ...i definitely feel like my blonde is showing today!
Appreciate the quick response, thanks again!
Efiladeeni
Postby closurdo » Sun Jun 29, 2008 12:34 pm
No problem! Glad that I could help.
closurdo
