Tear floor question
Tear floor question
Postby Lgboro » Sat Jul 05, 2008 5:05 pm
Has anyone used the interlocking flooring material for a tear floor? I'm not
sure about the weight but it seems to be plenty strong and would add a little
insulation. The price might be ok as my local Sam's has several open boxes
for less than half price. Shouldn't be any heavier than plywood topped with
flooring.
(I have an ribbed insulated floor)
[img][img]http://www.tnttt.com/gallery/image.php?image_id=37531[/img][/img]
Lgboro
Images: 53
Postby tinksdad » Sat Jul 05, 2008 5:27 pm
Are you talking about the laminate floor planks?? If so, be sure to read the labels very closely..... most of them are NOT recommended for areas that may be subject to wet conditions (i.e. kitchens and baths). They have to go over a solid subfloor, so I don't know how much weight you would be saving; but it would look good.
tinksdad
Images: 155
Postby Lgboro » Sat Jul 05, 2008 5:50 pm
Yes, I have a 1/4 inch exterior luan under 1 1/2 inches of dense foam
insulation in between the rib floor and then would put the laminate floor
planks. I know they can be put over concrete and I sure hope my tear is
dry that far from the ground. I guess the way my tear floor is built it would
be easy enough to replace if need be. Could be angled screwed in instead
of a floating floor for added strength.
Lgboro
Images: 53
Postby angib » Sun Jul 06, 2008 5:11 am
Having separate pieces means that the shear strength of the floor disappears completely, which would normally make your body wobbly - but if you have another layer of ply under the insulation, that will provide the shear strength needed to keep the body stiff.
But it sounds like extra work to get something that's not as strong or durable as a sheet of ply, and is hidden under the mattress, so why bother? 'Ness you want to, of course!
Andrew
angib
5000 Club
5000 Club
Images: 231
