http://www.clearplasticdome.com/clearplasticdome.htm
SuperTroll wrote:found this site and thought that it gives an opportunity to add some rather unique window possibilities to Teardrops.....
angib wrote:Please note that these domes need to have a flat base to mount on. So you'd need a teardrop like a Benroy with flat section between front and rear curves - and then you'd be limited to maybe 24" as the flat section isn't much longer than that.
Andrew
So-Cal Teardrops wrote:I can see it now, a bubble big enough to stand up and get dressed.
