Insulation glue???
Insulation glue???
Postby Eric Adams » Sat Mar 05, 2005 10:45 pm
I was wondering if that 3m spray glue in a aerosol can would work ok to glue insulation inside the walls? Anyone use it? I got it in Wal-Mart's craft section.... 8)
Eric Adams
Postby norm perkiss » Sun Mar 06, 2005 2:04 am
Eric,
Here is a link from a previous thread on gluing up insulation.
http://tnttt.com/viewto ... insulation
I used 3 layers of 1/2 inch foam board and trimed it for a tight fit, no glue.
Norm
norm perkiss
Images: 62
Postby Denzagrad » Sun Mar 06, 2005 1:04 pm
Eric, I'm not sure if it was the combination of foam, 3m spray adhesive and Gorilla glue or what. But once when doing the roof there was some strong (eye burning) type fumes that arose. I only noticed this when the foam came near an area that had the not quite dried Gorilla glue. I made sure the glue had cured completely after that before placing any foam near a glued joint. :thinking:
Denzagrad
Postby Eric Adams » Sun Mar 06, 2005 2:05 pm
norm perkiss wrote:Eric,
Norm
Cool...so Liq Nails + foam = melted foam. #M spray + foam = Good according to Kai! :)
Eric Adams
Postby Denny Unfried » Sun Mar 06, 2005 7:17 pm
I did mine like Norm with three layers of 1/2" polystryene and stuck them together with hot melt glue. Just has to hold it till you put the covering over the top. I've seen some folks use tape to hold it in place while covering.
Denny
aka - "Uncle Denny"
<img src="http://www.uncledennyscorner.com/teardrop/photos/Linux.gif">
Denny Unfried
sprint car builder/racer & all that jazz
Postby Steve Frederick » Sun Mar 06, 2005 7:46 pm
Denny Unfried wrote: I've seen some folks use tape to hold it in place while covering.
Denny
I used duct tape to hold the foam in place on the Stripper. Staples reinforced the hold.
As I recall, I took a lot of razzing for that!!Image
Blessings, Steve
Adirondacks, Upstate New York
Building Journals
Steve Frederick
Custom Teardrop Builder
Images: 29
