Trim length..need a seam?
Postby shoeman » Mon Jul 14, 2008 8:08 pm
My walls and galley were screwed and glued today. Phew. Now on to figuring the skinning.
I want to go aluminum. Problem is the roof line length requires a 9'9" piece to go from the front to the hinge. 8' seems the common dimension the top trim comes in. Can I butt two pieces together cleanly and make that work?
Longer pieces can be had for bigger shipping $$. Is that the best way to go and just bite the bullet?
Geoff
99% of the way done with a Generic Benroy. Only because these might never be done if you like to tinker. But it's on the road!
shoeman
Images: 22
Postby Endo » Mon Jul 14, 2008 8:16 pm
I have a butt joint on mine. I think it looks fine.
Brad (aka Endo)
ImageImage Image
In God We Trust
Endo
Images: 138
Postby Lgboro » Mon Jul 14, 2008 8:49 pm
You might find the longer moldings available locally from an RV dealer and
avoid the high cost of shipping. I found a local RV dealer that no only has
new parts but has a bunch of used parts he has salvaged at reasonable
prices. He stocks several moldings in lengths up to 20 feet.
Lgboro
Images: 53
Postby halfdome, Danny » Mon Jul 14, 2008 8:52 pm
Common practice in butting two pieces of molding is to cut each piece at a 15 deg angle. I did just that on the insert molding on TD#2 and it's hardly noticeable. :) Danny
halfdome, Danny
*Happy Camper
Images: 252
Re: Trim length..need a seam?
Postby Gage » Mon Jul 14, 2008 9:13 pm
shoeman wrote:My walls and galley were screwed and glued today. Phew. Now on to figuring the skinning.
Geoff
Are you asking about the aluminum sheeting or moldings :QM
Image Image Image
Gage
Images: 28
Postby shoeman » Tue Jul 15, 2008 6:48 am
It may turn out to be both! I'm having a bear of a time finding 5' wide AL sheets. Initially my question was about the roof trim.
My local guys don't stock diddly, and what they do is the modern stuff that uses a vinyl(?) insert and that looks too modern for me. I want old fashioned simple trim.
shoeman
Images: 22
Postby halfdome, Danny » Tue Jul 15, 2008 8:57 am
shoeman wrote:It may turn out to be both! I'm having a bear of a time finding 5' wide AL sheets. Initially my question was about the roof trim.
Look in sdtripper2's Index at the top of the page. Scroll down to the Aluminum trim and The Teardrop Fix It shop should be there. They carry the trim your looking for. There's also resources on aluminum sheets listed there.:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby Ken A Hood » Tue Jul 15, 2008 9:02 am
Here's a link to the go-rv.com dealers in Maine; don't know if any are close to you..
http://www.go-rv.com/coast/do/chooseDealer?state=ME
Ken A Hood
Images: 42
Postby shoeman » Tue Jul 15, 2008 10:01 am
One of those dealers is only a few miles from me. I called them yesterday and they said can order trim. Now I can see what they are selling in that GO-RV catalog. Guess I better call them again. Trouble with this stuff is the distributor sells it to dealers in 10pc lots and I only need 2 pieces. Wonder what that will do to the price?
Grant is working up an order for me and he's a helpful guy. I may end up going that way anyhow.
shoeman
Images: 22
Postby mechmagcn » Tue Jul 15, 2008 1:16 pm
shoeman wrote: Trouble with this stuff is the distributor sells it to dealers in 10pc lots and I only need 2 pieces.
I have an RV repair business and that is the same thing that I am running into. This trim is not exactly cheap. Let's see, 10 pieces, 20' each, that should be good for at least 5 teardrops. Guess I'll have the trim for the next build,and the next. :thinking:
Jeff & Micki
53 F100
Mercedes turbo diesel
Teardrop "finished" as if they ever are
You can never be lost if you don't care where you are going!
mechmagcn
Images: 56
Postby Airspeed » Tue Jul 15, 2008 9:29 pm
SAF has aluminum in 5'X10' sheets and are great to work with.
Airspeed
Images: 16
