I am getting ready to install the 26 gage metal roof and am using 1x¾ edge trim ( the kind with the vinyl insert that covers the screws) to attach to ½” ply walls. How much and where should I put the butyl tape? On both sides of the angle or only on top where the screws are going? Will the tape seal the hole when I screw through it?
The wall leg of the angle trim is bent slightly inward. Is this to accommodate the adhesive at the top? Should I try to pull it in enough when installing that it will be straight.
