Pullout Drawer for Cooler/Freezer
Postby Classic Finn » Thu Jul 17, 2008 11:43 am
I had the cooler/freezer in the galley and was wondering how to go about building the pullout drawer to it due to the fact that it needs air circulating around it? And how do I know it will be sufficient air movement?
Classic Finn ;)
Classic Finn
Midnight Sun Voyager
Images: 146
Postby Jst83 » Thu Jul 17, 2008 1:13 pm
Looks to be vented in the front so if you put in in the tray long wise with the vents to the front it should get plenty of air. If you wanted a drawer front you could put a vented one on and I still think you'd get enough air.
Just my thoughts as I've never tried to build one in.
Jst83
Images: 215
Postby Classic Finn » Thu Jul 17, 2008 3:21 pm
Do you think I should install a vent through the outside wall in that same location ? Would that help..? :thinking:
It wont fit long ways in.. so side ways it must be..
Classic Finn ;)
Classic Finn
Images: 146
Postby Jst83 » Thu Jul 17, 2008 4:42 pm
Classic Finn wrote:Do you think I should install a vent through the outside wall in that same location ? Would that help..? :thinking:
Classic Finn ;)
:thinking: Will it be all the way to the side? and on when the hatch is shut, I assume. I'd say probably, it would help from over heating the little motor.
But that puts a permanent hole/vent in the side :thinking: Maybe if you could vent the floor below it.
I'm sure someone has done this
Jst83
Images: 215
Postby madjack » Fri Jul 18, 2008 12:17 am
Heikki, unless the sliding drawer blocks the vent, I wouldn't worry about it...even in a closed galley, I bet the interior temps in your part of the world would never get hot enough to make a difference...remember that these units are made to work in the harsh climes of Australia and other similar places...above the Arctic circle should be no problem...just make sure that nothing is blocking them when the galley is closed up........
Postby PaulC » Fri Jul 18, 2008 2:14 am
Heikki, Jacks right. Those fridges are normally designed to run in temps much higher than you experience. Just make sure about not blocking it completely when it's in it's closed position.
Cheers
Paul :thumbsup:
PaulC
3rd Teardrop Club
Images: 36
Postby Classic Finn » Fri Jul 18, 2008 2:17 am
PaulC wrote:Heikki, Jacks right. Those fridges are normally designed to run in temps much higher than you experience. Just make sure about not blocking it completely when it's in it's closed position.
Cheers
Paul :thumbsup:
They use them here on boats and yachts and....now teardrops? :lol: :lol:
Classic Finn
Images: 146
Postby Classic Finn » Fri Jul 18, 2008 1:21 pm
I think I have a pullout figured out.. I just have to put it together and take a pic for your look see. :lol: :lol:
Classic Finn
Images: 146
Postby Classic Finn » Fri Jul 18, 2008 1:23 pm
would there be any difference in stabilizing the tear if I were to mount it in the middle versus the side as some have done?
Is there any difference in this?
Classic Finn ;)
Classic Finn
Images: 146
