Cedar Shingles On Sidewalls
Postby rxc463 » Sat Jul 19, 2008 7:16 am
I am making progress on my trailer design and I was wondering if you good folks could offer up some experience/suggestions on using cedar shingles on the sidewalls of the trailer. I realize that there will be an added weight factor, but the look will really fit the theme I have in mind.
I figure it should be ok if I use a good waterproof adhesive and glue the entire surface to the skin. A few staples here and there should do the trick. The leading edge of the trailer trim will be a bit higher than the shingles to prevent wind lift on the edge.
Hope to be closing the deal on an old popup this weekend, so construction may actually begin this year! :worship:
If you folks have any pics of such an installation, I would love to see them.
Russ
Politicians and diapers have one thing in common. They should both be changed regularly, and for the same reason.
rxc463
Images: 20
Postby closurdo » Sat Jul 19, 2008 7:54 am
You can take this for what it's worth ( my 2 cents ) but cedar shingles are nailed to houses in such a manner to not only keep them from leaking but because the need to expand and contract a little with temperature and humidity changes. I've never built a teardrop but I do occasionally work with wood and I would think that gluing the whole surface of the shingle would lead to some problems. If someone has had success doing this then I stand corrected (just hate to see you do a lot of work and have it get ruined).
Larry
closurdo
Postby satch » Sat Jul 19, 2008 9:49 am
I would think they would have to be glued down really strong to the walls. The first time you hit 60 mph on the highway it would look like dandruff in the wind :lol:
If it itches. scratch it
Rick
satch
Images: 63
Postby halfdome, Danny » Sat Jul 19, 2008 10:27 am
closurdo wrote:You can take this for what it's worth ( my 2 cents ) but cedar shingles are nailed to houses in such a manner to not only keep them from leaking but because the need to expand and contract a little with temperature and humidity changes. I've never built a teardrop but I do occasionally work with wood and I would think that gluing the whole surface of the shingle would lead to some problems. If someone has had success doing this then I stand corrected (just hate to see you do a lot of work and have it get ruined).
Larry
I agree with the above opinion. Cedar is very easy to split as in "Split Cedar Shingles" Wood moves no matter how well it's glued or fastened. The wind turbulence on the shingles should impact your gas mileage. :) Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby goldcoop » Sat Jul 19, 2008 12:59 pm
Hey-
What? Cedar on a TD... Must be a PA thing :lol:
I thought orginally shakes BUT used siding instead.
I too was concerned about the shakes blowing off. BUT with the siding you get 1pc full length for glue surface and nailing in on overlaps.
It'll be a Knoebels Grove Sept. 19 -21 if you wanna take a close up look.
Coop
goldcoop
Images: 32
Postby Juneaudave » Sat Jul 19, 2008 3:43 pm
Gee...here you guys go trying to suppress a guys creativity... :lol:
Ya know...I might consider shakes as an accent..not as a full covering. For a woody, I could definately see using ply over the top to get a good waterproof profile, adding nice wood edging, and cutting down some nice shakes to proportion to do an upper or lower half of the side to give character. I think you would be okay for most weekend trips and it could look really, really nice. Texture (like shakes as opposed to a smooth sides or painted color) is a wonderful attribute to work with to make something unique!!!
:thinking: :thinking: :thinking: :twisted:
Juneaudave
Images: 380
Postby mikeschn » Sat Jul 19, 2008 7:54 pm
I would find a guy with a CNC machine... and have him machine the texture of cedar shakes into the wooden sides... :)
Postby Juneaudave » Sat Jul 19, 2008 8:56 pm
mikeschn wrote:I would find a guy with a CNC machine... and have him machine the texture of cedar shakes into the wooden sides... :)
Good idea!!! That woud be sweet!!! :thumbsup:
Juneaudave
Images: 380
Postby 2bits » Sat Jul 19, 2008 11:48 pm
You could always use cedar fence boards! Just kidding, I just love this one tho...
Thomas
2bits
2bit Member
Postby jagular7 » Mon Jul 21, 2008 12:36 pm
Vinyl house siding now adays has a lot of geometric figures on the face. I've seen u-drop shingle and offset-wood shingle layouts. Take this, cut, trim, overlap if they are small (available in 4x8 and x10 sheets), seal up the edges, and have it painted to the color of cedar with shadows to give it that depthness look.
Mike
Jagular
Lenexa, KS
jagular7
