Ricky
sushidog wrote:...I was thinking of building a nosecone for my Aliner out of the corrugated plastic material like they make signs out of...
Q: Is it possible to bond or glue two pieces of Coroplast® together?
A: Polypropylene is great for many uses due to the fact that it is resistant to chemicals; unfortunately the same properties make it difficult to bond using chemical bonding agents. However, several products have been developed recently by companies such as 3M that are designed to bond polypropylene structurally. Coroplast has not yet tested these products fully. 3M's Scotch-Weld™ Structural Plastic Adhesive DP-8005 is available from Grainger and other distributors for industrial use.
Heat welding with proper tools is an excellent method to bond two sheets of Coroplast®.
Users browsing this forum: Bing [Bot] and 6 guests
