any ideas?
I picked up my axle today, it's a Dexter#9 with 22.5deg down angle. When I ordered it, they asked for the frame width which is 60in, that is fine. I ordered a an axle 74in face to face, which takes into account the offset of the wheels with a 2in gap between the wall and the tire that is fine also. What I didn't know was the distance from the bracket to the swing arm is only 1in. My walls are 1in so it will be a tight fit.
Any ideas? One that came to mind was to use the router and rout a recess along the swing arm travel (a pie slice shape) then glass and epoxy it for protection from moisture.
