Getting silicone prints off the skin?
Postby shoeman » Tue Aug 05, 2008 8:55 am
Any tips on cleaning up my skin when I'm done? It's impossible to avoid getting fingerprints and smears from the silicone sealer all over the place when I'm assembling everything.
99% of the way done with a Generic Benroy. Only because these might never be done if you like to tinker. But it's on the road!
shoeman
Images: 22
Postby alffink » Tue Aug 05, 2008 3:22 pm
shoeman,
There are a couple very similar products that work pretty good on realitively fresh silicon, 'OOPS" and "GOOF-OFF", both are formulated for remove adhesive mess from most hard surfaces, be careful around finished wood and fresh paint, if unsure test.
It has even been successful in removing silicon caulk from my window frames and aluminum skin, installed nearly two years ago.
This is an MEK, Acetone type product wear gloves.
These products can be found in the same area as the paint thinners and adhesives in the big orange box stores and their like.
alffink
Images: 37
Postby S. Heisley » Tue Aug 05, 2008 5:22 pm
If your wife or girlfriend have any fingernail polish remover around, try a little of that on a paper towel, rubbed on the spots. Its base is acetone and it has skin conditioners in it to buffer the effects on nails and skin.
If the garage silicone glue, etc. has already dried on your hands, just soak your hands in water and a little dish soap and you should be able to peel it off. Do this at the end of your garage "work-out" and then dry them and put on some hand lotion to sooth and protect.
Here's a sneaky thing to do: Offer to do the dishes for your wife. She'll love you for it and may never catch on! :lol: :lol: It'll be a Win-Win for both of you!
Best Wishes,
Sharon
Postby shoeman » Tue Aug 05, 2008 5:37 pm
S. Heisley wrote:If your wife or girlfriend have any fingernail polish remover around, try a little of that on a paper towel, rubbed on the spots. Its base is acetone and it has skin conditioners in it to buffer the effects on nails and skin.
Best Wishes,
Sharon
Thanks Sharon, but I meant the trailer skin, not mine! :lol:
shoeman
Images: 22
Postby asianflava » Tue Aug 05, 2008 8:04 pm
We used a silicone and wax remover called Pre-Kleeno at the paint shop I used to work at. I looked at the ingredients and it was naptha and alcohol. One good thing about that Pre-Kleeno, we were able to use it on plastic parts to remove the mold release and not melt the plastic.
You could try some naptha on a rag and see how it does on a small spot.
asianflava
Postby shoeman » Wed Aug 06, 2008 6:44 am
Best Wishes,
Sharon
Hey, wait a minute! I already do the dishes and I cook a lot too.
shoeman
Images: 22
Postby daddiozz » Wed Aug 06, 2008 6:57 am
shoeman wrote:
Best Wishes,
Sharon
....me too :( ;) ...any female types out there wanna apply for the position? i have an opening ...the pay is lousy but the fringes are pretty good...
daddiozz
Images: 5
Postby S. Heisley » Wed Aug 06, 2008 7:45 am
....me too ...any female types out there wanna apply for the position? i have an opening ...the pay is lousy but the fringes are pretty good...
I can't resist: Where have you been all my life????!! :lol: :lol: :lol:
Postby halfdome, Danny » Wed Aug 06, 2008 10:36 am
I use plain ole' lacquer thinner. :D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby dmckruit » Wed Aug 06, 2008 11:33 am
You shouldn't use ketones (acetone (finger nail polish remover) or mek (methyl ethyl ketone) to clean up painted surfaces as these are strong solvents and can ruin the finish.
I would only use these on bare metal surfaces. Your best bet would be use an aliphatic solvent such as mineral spirits, VM&P naptha or alcohols such as isopropyl alcohol (rubbing alcohol) or ethanol. These solvents are weak enough that they won't damage the finished surface of the object that you are trying to remove things from.
dmckruit
Images: 212
Postby daddiozz » Wed Aug 06, 2008 9:57 pm
...that all depends on how long a life you've had....14 yrs (collectively) in W VA and 36 in Ga....I noticed you have a "thing " for pvc ,check out "my" thread... PVC/TTT... ;)
daddiozz
Images: 5
