Question about installing a Kinro window
Postby Dragonryder » Thu Aug 07, 2008 10:35 am
Hello again, I just recently purchased a large Kinro window that I would like to install in my teardrop. I have no idea how to install it. I have the outer window and the inside ring and it is made for my wall thickness so all should be fine. The inside ring has screw holes all the way around the rim but the window does not. I see a plastic rim attached all the way around the middle of the window. I was thinking that the screws make there own holes in the plastic rim thus clamping the window and inner trim ring to the wall. Does this sound reasonable??? :thinking: I received an e-mail from the company but all they show is how to make sure that the window should fit in the wall. It doesn't show where the screws go into. :(
Any help with this would be greatly appreciated!!!
Have a great day and hoping the weather is great no matter where you are!!!
Signed, Me
Dragonryder
Images: 19
Postby Mary K » Thu Aug 07, 2008 10:51 am
I think you are correct. In my case there was a grove that the screws screwed into. I did installed mine with the interior ring. Madjack will tell you to dump the ring and drill holes on the out side of the window trim..... Here are some links to other that have asked similar questions.
Linky 1
Linky 2
Linky 3
Good Luck!
Mk
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby Dragonryder » Thu Aug 07, 2008 10:54 am
Thank you. I'm getting down to the nitty gritty on putting my camper together and this was one of the things that was holding me up. :applause: :thumbsup:
Have a great day and may the weather always be good!!!
Signed, Me
Dragonryder
Images: 19
