McBrew's Cub Build
McBrew's Cub Build
Postby McBrew » Tue Sep 09, 2008 9:34 am
I've been fooling around with my HF trailer for a couple of months, but I have finally made a little progress "above the floor." Here are a few pictures that my fiancee (Brandy) took while I was "working." I am cutting a template from MDF board. Later, I'll clamp plywood to it and use a router to make my inner and outer walls.
Here I am placing screws for the string.
Drawing the curves.
Here is the rough cut shape.
The next step is to belt-sand it down to the exact shape. I'll get that done sometime this week.
-Jesse
1984 Scamp 13'
In the process of bringing it back to its former glory... if not better!
McBrew
Postby Miriam C. » Tue Sep 09, 2008 10:56 am
:woohoo: :thumbsup: :applause: Great profile Greg! Now for some real sawdust!
Nice shape.
Postby BillandMarijo » Tue Sep 09, 2008 11:21 am
Nice shape. Your going to be hooked now. Lol
Bill :thumbsup:
Hope to see you on the road.
Bill and Marijo
Also We Are On Facebook
Friend Us.
Bill Peterman
Marijo Haselbarth Peterman
BillandMarijo
Images: 36
Postby McBrew » Tue Sep 09, 2008 5:56 pm
Thanks... but I'm Jesse, not Greg... lol! :?
-Jesse
1984 Scamp 13'
McBrew
Re: McBrew's Cub Build
Postby angib » Wed Sep 10, 2008 5:06 pm
McBrew wrote:Here I am placing screws for the string.
Good photos - may I steal them to add to the ellipse-drawing guide?
Any problems with 'string stretch' and what did you use? Just regular organic string?
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby McBrew » Wed Sep 10, 2008 7:15 pm
Andrew
If they will help at all, please use them! The string I used was a little stretchy, but it helped to make everything line up. It was just some construction string that I've used for everything from plumb bob work to pouring concrete.
-Jesse
1984 Scamp 13'
McBrew
Postby McBrew » Fri Sep 12, 2008 6:55 pm
I used my planer and belt sander to get the shape of the MDF template finished up today.
I also worked out the location of the axle... which wasn't as straight forward as I had hoped. Those Harbor Freight trailers aren't perfectly square :x . Oh well. The axle is clamped into position... I just need to drill and bolt it onto the frame. I guess I'll need to remove the axle and bolt the brackets to the frame, then reinstall the axle to the brackets.
I am seriously thinking about a painted roof instead of bare aluminum. What about Filon? y RV has a Filon roof and it is some tough stuff. I am guessing it isn't too hard to paint. I am thinking a green roof would go well with the woody sides.
-Jesse
1984 Scamp 13'
McBrew
Postby McBrew » Fri Sep 19, 2008 6:02 pm
I got the frame drilled and the axle bolted into place today! I also finished bolting down the wood frame to the trailer and stapled the floor onto that. Finally, I primed the top of the floor so that I can put the vinyl tiles on and I finished painting the frame black.
-Jesse
1984 Scamp 13'
McBrew
Postby BillandMarijo » Fri Sep 19, 2008 6:11 pm
H :applause: ey;
Looks good. Looks like your on your way.
Enjoy the build.
Bill
Bill and Marijo
Friend Us.
Bill Peterman
BillandMarijo
Images: 36
Postby McBrew » Sat Sep 20, 2008 8:07 am
After taking a shower, cooling off, and having a gin & tonic (like spinach to Popeye), I headed back down to the garage and laid the floor tiles. They're standard 12" vinyl Armstrong tiles.
It's going to be a while before I can devote some real time to the project. I've got to work all this weekend, then my soon-to-be inlaws are throwing us an engagement party next weekend up in Gettysburg, and then I work the following weekend.
I will have October 3rd off... hopefully I can get something done that day. :?
-Jesse
1984 Scamp 13'
McBrew
Postby toypusher » Sat Sep 20, 2008 8:12 am
Jesse,
Looking good! Should really start taking shape now.
BTW: If you have time while in Gettysburg, go visit the new Visitor's Center. It is really great!! Of course, I am a Civil War buff of sorts!! :)
toypusher
Images: 324
Postby McBrew » Sat Sep 20, 2008 9:26 am
Thanks for the words of encouragement! I just hate having nearly three weeks where I won't be able to do any serious work on it. I went out last week and bought the air conditioner and I was just in time... a lot of stores have stopped selling them for the year. I was able to snag an electronic 6,000 BTU unit for $105!
-Jesse
1984 Scamp 13'
McBrew
Postby 2bits » Sun Sep 21, 2008 8:04 pm
Hi Jesse,
As a fellow Cub builder I will follow your build with anticipation! I am in the home stretch on mine and I know how it feels knowing it is in the garage calling to you to spend some time with it!
Thomas
2bits
2bit Member
Postby Sam I am » Sun Sep 21, 2008 8:37 pm
Great looking floor, Jesse. Be careful not to damage it when you finish the interior. I put my floor tiles in last because I knew I would hog it up if i didn't. Sure enough, I slopped drops of glue and varnish on my plywood floor, then just covered them up with tile!
Sam
Sam I am
Images: 106
Postby McBrew » Fri Jul 17, 2009 9:34 pm
It's been a LONG time, folks... I've been working a lot... got married... having a baby... whew!
Since I have limited time and an even more limited budget, I have scrapped the Cub design and am going for a generic Benroy. I switched from sandwich type walls to just 3/4" ply. The roof and floor will still be insulated. It is 4' wide to cut down on wind resistance and weight, since it will be towed by a subcompact car.
In two days, I got the walls cut, doors cut out, most of the roof spars put in, and got a good start on the cabinets. Here's a lousy cell phone pic includeing my two helpers:
-Jesse
1984 Scamp 13'
McBrew
